robcampbell
May 03, 2021Aspirant
How to connect Nighthawk A7000 to Fedora 33 with no internet access and no CD ROM?
 My desktop is in a place were I can no longer have wired access.  So I did some research and a few reviews said this wifi adapter was the best.  I should've searched more specifically for Linux relat...
May 04, 2021Guru - Experienced User
that device is only approved for mac/windows.
If you've found someone thats getting it working on linux, I'd simply move the computer to where there is wired access and then follow their guide. once its installed, move it back. or purchase a really long ethernet cable for the install process.
