robcampbell
May 03, 2021Aspirant
How to connect Nighthawk A7000 to Fedora 33 with no internet access and no CD ROM?
 My desktop is in a place were I can no longer have wired access.  So I did some research and a few reviews said this wifi adapter was the best.  I should've searched more specifically for Linux relat...
michaelkenward
May 05, 2021Guru - Experienced User
robcampbell wrote:
I see some references to using git and connecting to someone's project but not only does that seem a little suspect but I don't have internet access so... How would I be able to get this device to work on my desktop?
You don't tell us what you read about getting your device to work in Linux, but if it is a case of installing something on your PC, then you may be able to download the necessary software/drivers elsewhere (with whatever you use to post messages here?). Then just go through the installation process while offline.
This is exactly the same process as you can use to install the drivers on a Windows PC with no CD drive.
Download drivers to one device > copy on to portable storage > move storage to PC > install from here.
