modab
Jun 01, 2022Follower
how to get a6100 running on fedora KDE
how do you get ac600 running on fedora kde? nothing has worked and I can't just use this old 80s belkin adapter (it can't run a thing except this forum)
Jun 01, 2022Guru - Experienced User
The A6100 is only supported on windows 10.
If you wanted to get it working on fedora, you might ask on their forums for help getting it running.
It uses a realtek rtl8811au chipset
there might be generic drivers on fedora for installing that
