Alex_taylor
Jul 14, 2019Tutor
I enabled SMART CONNECT and it ended my internet forever
So heres my issue with their product.
1) who ever designed the interface of these products is down right mentally retarded
(Need to connect to your router? first connect to the wifi.... but wai...
Jul 15, 2019Guru - Experienced User
Ya you need to post in the wifi adapter forum for your model adapter.
https://community.netgear.com/t5/WiFi-Adapters/bd-p/home-wifi-adapters
Sounds like a mis-configuration.
Good Luck.
(Need to connect to your router? first connect to the wifi.... but wait having wifi issues? want to connect to your router to fix them? connect to the wifi to access it... Tough luck)
2) The fact that they charge you for help on a product that YOU BOUGHT FROM THEM shows how much of a money mongering corperation this is.
(Called customer support... "Hello let me check to see the issue (Checks first to see if I have a subscription to them) Oh I know the solution and its an easy one BUUUUUTTTTTT you have to pay upwords of 200$ to fix your small issue." THAT I KNOW IS CAUSED BY THE RETARD WHO DESIGNED THEIR SOFTWARE IN THE FIRST PLACE
3) again with the design and these are the issues
I enabled smart connect and it **bleep**ing ended my internet forever
Tried to hard reset it now I cant even access my og settings
Found a post similar and this is what they said..... not very helpful
"when connecting to wifi the device reports an incorrect password.
Testing
I have done a lot of testing and can reproduce this error every time.
I have been able to reproduce this issue in router mode and AP mode.
these things all failed
- changing password on router and device
- factory resetting device
- using a working ios device to setup a new ios device
- trying to attach a device that was brand new to the network
- factory reset router and re configure.
Solution:
The simple solution to this is uncheck Enable Smart Connect. When this is enabled its hit or miss on a working WiFi."
This was coppied from someone else who fell into this retarded ass loop as me
HOWEVER, This is all they said....
I CANT ACCESS THE **bleep**ING APP IF I CANT CONNECT TO THE DAMN WIFI IN THE FIRST PLACE SO HOW THE **bleep** AM I SUPPOSED TO FIX THIS?!?!?!?!?!?!?!?!?!?!?!?!?!?!?!?!?!?!?!?!?!?
I've been trying to fix this **bleep**ing issue for 3 hours now pooring over community threads and cant find a damn solution this company has down right lost me as a customer forever due to these cheap ass tactics of do it yourself **bleep** for a broken ass router they **bleep**ing made.
RANT OVER
All seriousness if you have a real solution and can post Clear step by step on what I need to do in order to get this **bleep** working again before I literally throw it out in the road and run it over with my car before setting fire to it and pissing on it I would love it.
