Alex_taylor
Jul 14, 2019Tutor
I enabled SMART CONNECT and it ended my internet forever
So heres my issue with their product.
1) who ever designed the interface of these products is down right mentally retarded
(Need to connect to your router? first connect to the wifi.... but wai...
Alex_taylor
Jul 16, 2019Tutor
see it would be that easy if it worked i have it currently plugged into the port and it wont even register that its plugged in so i cant access it that way...
Jul 16, 2019Guru - Experienced User
Ya you need to post in the wifi adapter forum for your model adapter.
https://community.netgear.com/t5/WiFi-Adapters/bd-p/home-wifi-adapters
Try the adapter in a different PC to test, if it fails there too, then the adapter is probably just bad and needs to be RMAd.
Contact NG support for help and information regarding this.
Good Luck.
- michaelkenwardJul 18, 2019Guru - Experienced User
Oh dear, we seem to have a confused bunny here:
SMART CONNECT DESTROYED MY ROUTER - NETGEAR Communities
