udewu
Oct 23, 2021Aspirant
I recently upgraded ISP to 400mbps, but my router speed tests only gets to 200 mbps AC1750 R6400v2
I upgraded my ISP from 200 mbps to 400 mbps but noticed no change in speed. I had my ISP provider come change out my modem and wiring to the house and the speed gets 400mbps to the modem, just not f...
cscott1
Oct 23, 2021Guide
I had the same router and i was getting similar speeds I downgraded the firmware to 1.0.2.52_1.0.39
all the firmwares are found here https://www.netgear.com/support/product/r6400v2.aspx#download
I updated to Gigabit service and the routers wifi Download speeds improved to 320 Mbps on 5G after doing the downgrade in the firmware. Wasnt enough for me so I purchased the RAX50 and my numbers more acurately reflect my speeds but give the firmware a try 320 of 400 wouldnt be too much of a loss...
udewu
Oct 24, 2021Aspirant
Thank you very much for taking the time to provide input.
