udewu
Oct 23, 2021Aspirant
I recently upgraded ISP to 400mbps, but my router speed tests only gets to 200 mbps AC1750 R6400v2
I upgraded my ISP from 200 mbps to 400 mbps but noticed no change in speed. I had my ISP provider come change out my modem and wiring to the house and the speed gets 400mbps to the modem, just not f...
Oct 23, 2021Guru - Experienced User
1. Make sure with the R6400 that qos, access control, traffic monitoring, and parental controls are all disabled and then reboot the device.
2. you might need to factory reset if you had those settings enabled but try the disable and reset first
3. you won't max out 400mbps over wireless with that device. Its a base model gigabit device. You should be able to max out the 400mbps if you're hardwired into it.
4.You don't put how you're testing, what you're testing on, etc so its tough to tell exactly what testing procudures you're using.
udewu
Oct 24, 2021Aspirant
I appreciate the input, I will try those steps and see if that helps.
- plemansOct 24, 2021Guru - Experienced User
Try it and see how it works.
next time you do have an issue, the forum for your device is this one:https://community.netgear.com/t5/General-WiFi-Routers-Non/bd-p/home-wifi-routers-general
Not a big deal but you'd get more help than the forum for "wifi adapters" :)
The forums aren't the easiest to navigate
