udewu
Oct 23, 2021Aspirant
I recently upgraded ISP to 400mbps, but my router speed tests only gets to 200 mbps AC1750 R6400v2
I upgraded my ISP from 200 mbps to 400 mbps but noticed no change in speed. I had my ISP provider come change out my modem and wiring to the house and the speed gets 400mbps to the modem, just not f...
udewu
Oct 24, 2021Aspirant
I appreciate the input, I will try those steps and see if that helps.
Oct 24, 2021Guru - Experienced User
Try it and see how it works.
next time you do have an issue, the forum for your device is this one:
https://community.netgear.com/t5/General-WiFi-Routers-Non/bd-p/home-wifi-routers-general
Not a big deal but you'd get more help than the forum for "wifi adapters" :)
The forums aren't the easiest to navigate
