paulie12
Dec 26, 2020Guide
I think I solved the a7000 USB 3.0 issue... Thoughts please.
I think I solved the problem with the A7000 that turns off intermittently and also the problem with it only using USB 2.0 speeds. It seems the problem with ALL usb wifi dongles is overheating. I bel...
paulie12
Dec 29, 2020Guide
Spoke to soon. I got a good 5 hrs out of it then it disconnected. I can't reconnect and my windows doesn't recognize any USB 3.0 ports. The port shows a triangle with exclamation point on the 3.0 USB port and it won't let me reconnect unless I restart the system. I'm going to do more digging but 5 hrs is a lot more than I've gotten in the past.
paulie12
Jan 15, 2021Guide
I solved it: Purchase a powered USB 3.0 hub and connect it to that.
- njwebJun 02, 2021Luminary
paulie12 wrote:I solved it: Purchase a powered USB 3.0 hub and connect it to that.
Thanks Paulie!
After wasting 3 days with this issue (one computer works fine with this adapter, the other one has the issues EVERYONE is complaining about - where you either have to deal with disconnects out of the box OR disable the RunSwUSB which prevents disconnects, but at the expense of consistent / high speeds).
Since the adapter works fine in one of my computers - speeds of 858 Mbps without a hub with no disconnects, whereas it has issues with my other newer computer - disconnects after a while and computer has to be rebooted or adapter has to be removed), I am convinced it is a USB chipset / USB power issue and your hub solution makes sense.
Which hub are you using?
- michaelkenwardJun 03, 2021Guru - Experienced User
njweb wrote:
....I am convinced it is a USB chipset / USB power issue and your hub solution makes sense.
Do you think it could be down to the Windows drivers for the USB chipset? (Not the drivers for the USB adapter.)
I mention that because the same thing has happened with wifi chips, no USB anywhere in sight.
Windows update rarely picks up driver updates at the motherboard/chipset level. The only way to get those updates seems to be to track down the motherboard maker's site and to see what they have to offer. In some cases it is down to finding the chipset maker. For example, in the case of the wifi problems, it was Intel that had the right drivers. Another regular guilty party is Realtek, which does audio, wifi and bluetooth chips.
- njwebJun 03, 2021Luminary
michaelkenward wrote:
njweb wrote:....I am convinced it is a USB chipset / USB power issue and your hub solution makes sense.
Good points. I would not be surprised if it could be USB drivers, although it appears Netgear drivers have an issue; note that they have not been updated since 2017 (if they were working fine that would not be a concern).
The USB switcher appears to be most of the issue; the adapter seems to revert from USB 3.0 to USB 2.0 / reduce throughput when it does not need to or otherwise possibly because it generates too much heat?
Turning off the switcher seems to put it in USB 2.0 eventually, which brings speeds down.
The speeds observed / behavior of the A7000 are odd / inconsistent, especially on certain USB ports / USB controllers.
I ordered a powered USB hub (not ideal due to extra cost and another cord across the floor to the outlet) to test paulie12's potential fix.
While waiting for that, I will see if anything else could help... Not seeing any USB or chipset drivers for my laptop (Samsung Galaxy Book Flex).
I am going to leave the service (RunSwUSB) enabled for several days and try to track how it fares.
Ran three speed tests just now and got 608, 680 and just under 718 Mbps.
Now the test is to see whether BOTH wifi download speeds and connectivity remain stable all day today / the next few days.
