deepakdhingra
Jan 07, 2025Follower
Installation Failiure - MAC OS Sequoia Version 15.0
Unable to complete the installation for A6150 adapter. Throws the error (see screen shot.) Any help is greatly appreciated ? Is it not compatible ? Should i return the product ? OS - MAC OS Sequoia ...
Jan 08, 2025Guru - Experienced User
I'd return it. The datasheet shows only compatible to version 10.15.7 of mac. Quite a bit behind.
Better to find something that has a generic driver you can use and is a bit higher performing (the A6150 is pretty slow too)
