deepakdhingra
Jan 07, 2025Follower
Installation Failiure - MAC OS Sequoia Version 15.0
Unable to complete the installation for A6150 adapter. Throws the error (see screen shot.) Any help is greatly appreciated ? Is it not compatible ? Should i return the product ? OS - MAC OS Sequoia ...
Iko-NG
Jan 11, 2025Aspirant
Same issue here. I am on Sonoma. This adapter was the only USB WIFI adapter that listed compatibility with Mac OS in the entire store (BestBuy). Everything else required Windows. Any recommendations? I am all ear. TIA
- michaelkenwardJan 12, 2025Guru - Experienced User
Netgear lists a couple adapters as Mac OS compatible but it has a hard time keeping up with Apple's changes. Windows seems to be easier to manage, although even there older adapters can have problems with newer versions.
I'd ask that question on a Mac group.
An alternative, where circumstances allow, might be to install an internal WiFi card. That is a better bet for Windows although yet again the choice may be limited for Mac OS. Netgear doesn't make these cards.
The dearth of options available in BestBuy may be a sign.
Just another user with time on their hands.
- plemansJan 12, 2025Guru - Experienced User
Disclaimer: I'm not a MAC guy. I have zero and probably won't because of past experiences.
With that said, a lot of the forums with posts about USB adapters for macs show they've not been allowing them to be installed at the OS level. What most are recommending on the forums is getting an extender with an ethernet output, picking up a lightning/usb-c to ethernet adapter, and just hardwiring in the mac to the extender. Problem is that it isn't portable.
Another option is to search their (mac's) forums for potential devices that *might* work.
Seems to me like the best option.
For some unknown reason, Mac users are rare contributors around here. At least, there aren't many posts from people who own up to using Mac OS.
