Kocmoc
Nov 30, 2023Follower
Issues installing A6150 wifi USB adapter in Windows 10
Hi, I am trying to setup Netgear A6150 wifi usb adapter for Windows 10, it says I have to install software from the link below and then insert the device. When I am doing so I am getting the device ...
- Nov 30, 2023
Expand the A6150_Windows_Standalone_V1.0.0.5.zip
Then run the A6150_Windows_Standalone_V1.0.0.5.exe, and you get everything required in C:\Program Files (x86)\NETGEAR\NETGEAR A6150 Genie\Drivers
Point Windows to this folder with the netrtwlanu.inf and up you go.
schumaku
Nov 30, 2023Guru - Experienced User
