Unit
Sep 25, 2023Aspirant
Issues with AC1200 wifi adapter
So for awhile i used this ac1200 usb 3,0 wifi adapter and it helped alot but now im getting quite a few issues, for an example wifi randomly disconnecting and reconnecting and for some reason even co...
Unit
Sep 26, 2023Aspirant
Hello i have the whatever the latest windows 10 version is i don't see any updates all my drivers are up to date and i tried all my usb ports it does the same thing
michaelkenward
Sep 26, 2023Guru - Experienced User
That doesn't tell us much. There may be several "latest windows 10 versions". (I run a couple of different Windows 11 builds.) I doubt if that is crucial but these can mess around with existing devices.
Then there are the windows drivers for USB on your motherboard. They are usually crucial, but you never know.
As to you mean by "whatever the latest", we don't know how you determined that. Numbers matter.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
That page will also have any software, firmware and drivers for your device, if they exist.
- UnitSep 26, 2023Aspirant
Ok. Well the version says 22H2 and the os build says 19045.3448 i have already tried looking in documents nothing seems to help.
