gnbalbion
Oct 30, 2015Aspirant
MediatekSw Application Crashes Daily in Reliability Monitor
Hello,can you please help me on this one, I am running the Netgear A6210 USB Adaptor on my Intel based PC. The USB Adaptor MediatekSw Application crashes daily. Do I need this application to be runni...
JamesGL
Nov 07, 2015NETGEAR Employee Retired
Hi gnbalbion,
If you have an option for disable it then you may do so. Try to use as well the driver from NETGEAR instead of MediaTek.
http://support.netgear.com/product/A6210
JamesGL
Community Team
- gnbalbionNov 07, 2015Aspirant
Thank you for the reply, I am using the Netgear Driver, maybe the mediatek came fom the prior installation, I will check further,, thanks
