Brice123
Mar 29, 2022Tutor
Model: A7000|Nighthawk AC1900 WiFi USB Adapter - USB 3.0 firmware V1.011.134
Hi, My new Router is losing connection at least once a day. Mostly around 9:00PM I have to reboot it and everything works fine till the next day. Before I call and deal with Netgear does anyone have ...
Brice123
Mar 30, 2022Tutor
Yes sorry R7000 AC1900
I don't know router/gateway. It is a modem supplied by Spectrum the internet company. Everything was working fine then the last week it started kicking me off. I have to reboot and everything works fine till about 9 or 10PM at night then I have to do it all over again.
michaelkenward
Mar 30, 2022Guru - Experienced User
Does it have a label on the side? Most do.
Many ISPs supply modem/routers. This complicates issues.
Does the modem have a row of Ethernet ports on the back?
- Brice123Mar 30, 2022Tutor
No just one of internet to the router.
I will have to write back after I get home from work to check on that. Thanks for your help.
