lnorris
Jan 02, 2022Initiate
Moving RN202 from one location to another
Our office in process of moving. I have created Readycloud account and tested my 2 users access to the Readycloud documents after taking the NAS offline. They were able to connect into the cloud and ...
- Jan 02, 2022
This section is all about USB adaptors. Not much in common there with NAS storage.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
ReadyNAS Network Storage: Official NETGEAR Community
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
michaelkenward
Jan 02, 2022Guru - Experienced User
Support | NETGEAR
lnorris
Thank you. I decided to dive in and try and it worked. Unfortunately, I was thrown into this role so it has been trial and error as I have found out. Problem all solved.
