PureW
Dec 22, 2019Follower
My A7000 Cannot detect 5GHz networks, but my other devices can.
My desktop can detect the 2.4GHz network at my home but not the 5Ghz one when i use the A7000 adapter. My brother and I have the exactly same desktop, but he is using a different adapter (D-Link) on ...
Entaum
Apr 08, 2020Initiate
In case anybody still has still issue, here is the solution: https://www.youtube.com/watch?v=qtCGyTxXzU4
Basically the issue is with the NetGear crapware that is installed (no idea why we are being forced such a bad piece of software):
- Find the NetGear folder in Program Files (x86)
- Copy the Driver folder anywhere else (desktop is fine)
- Go to Device Manager, right-click on your A7000 adapter, click Uninstall - Make sure to check "Delete the Driver Software"
- No need to restart, just ignore if prompted
- Go back to the Device Manager and find your A7000 adapter. It should now appear as an unidentified device (it its not, repeat uninstall step above)
- Right-Click on it and select Update Driver and select Browse My Computer for Driver Software
- Navigate to the Driver folder you copied in the second step and just click continue.
Problem should go away!
