mikerr
Feb 23, 2026Aspirant
My A7500 ADAPTER
I just purchased this adapter and when Im trying to install the driver the window that should open to process the insrall does not open. I installed on my laptop and had no problem. But in my desktop...
Feb 25, 2026Guru - Experienced User
You say you've opened them but we still don't know what you see.
Did you try uninstalling all the drivers and installing a standalone driver?
mikerr
Feb 25, 2026Aspirant
I wish I could upload a photo here to show you. You know when you right click you get the menu if you want to disable or unintall or update your driver? Well I tried theough there and it just says no driver found. When I click on the unknown device it just reads there in the box to hat there is no driver installed for this device and i tried through there and got the same results. Wherever ive installed the previous adapter ive installed this adapter and it doesnt work or install the driver. I just also went in and turned off the smart screen settings. And nothing worked
