Wontairr's avatar
Wontairr
Follower
Jul 10, 2021
My Netgear A6210 keeps disconnecting, I have tried everything.
I use a Windows 10 64bit pc with a Nvidia gtx 1060 3gb [GPU] and AMD Ryzen 7 3700x [CPU] with a B450 Tomahawk Motherboard. The netgear a6210 that I own randomly disconnects, forcing me to either plug it out then in again out of frustration or reconnect to the internet on my pc.
I have done everything including: Unchecking the "Allow the computer to turn off this device to save power" which did nothing. I have done the same to the USB root hubs aswell. I have set the startup type to the NetgearSwitchUSB Service to Disabled, and it is currently stopped. That didn't work either.
Please give me a new solution to fix this stupid problem. I have literally bought so many wifi adapters and each one fails me.
