beachbug
Oct 16, 2021Aspirant
N300 WiFi Range Extender
Can I use my N300 in connection with a mobile phone which has poor connection with the existing router?
beachbug
When my wife uses her mobile phone in a room remote from the router, the signal is weak she has trouble connecting to the internet. The set up instructions for the EX2700 seem to imply that its main use is for laptops or similar. How can she set up her phone with the EX2700 to improve internet connection?
Oct 16, 2021Guru - Experienced User
it'd be just like with a tablet/laptop. Install the extender and then simply connect the phone to its wifi.
It can easily be used with phones. Nothing special to do for it.
You can find install guides, manuals, and firmware for the ex2700 here:
