beachbug
Oct 16, 2021Aspirant
N300 WiFi Range Extender
Can I use my N300 in connection with a mobile phone which has poor connection with the existing router?
michaelkenward
Oct 17, 2021Guru - Experienced User
If you have an EX2700 installed on your network, then you should be able to connect the phone to that in the same way that you connect the phone to any other wifi source. You just need to find the SSID from the EX2700 and connect to that with the right password.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
WiFi Range Extenders & Nighthawk Mesh - NETGEAR Communities
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
