rosebud505
Feb 14, 2020Aspirant
N300 Wireless USB Adapter WNA3100 Unable to connect to Internet with new PC and Windows 10
I just purchased a new PC with Windows 10. I'm unable to connect to my wireless router with the WNA 3100 adapter. I was able to install the setup CD on the computer but when I try to open up the WNA 3100 this message comes up: There are no compatible drivers for this device.
I also get this: The drivers for this device are not installed: (Code 28)
Because I am off line I'm unable to download any kind of update.
Is there any way to install this device on my computer?
Please help
Almost certainly too old. This thing dates back to 2013.
There are drivers for Windows 10 and this device.
WNA3100 (N300) Wireless USB Adapter Support | NETGEAR
then here:
WNA3100 Software Version 2.2.0.4 (Supports Win8/8.1) | Answer | NETGEAR Support
You managed to post this message here.
Try downloading the new drivers and transferring them to a USB drive. Install from that.
Some USB adapters will use the generic drivers that come bundled with Windows.
then here:
- rosebud505Aspirant
Thank you. That worked.
rosebud505 wrote:
That worked.
The download and USB install or the "native" drivers?
I ask for the benefit of anyone with the same issue in future.
