rosebud505
Feb 14, 2020Aspirant
N300 Wireless USB Adapter WNA3100 Unable to connect to Internet with new PC and Windows 10
I just purchased a new PC with Windows 10. I'm unable to connect to my wireless router with the WNA 3100 adapter. I was able to install the setup CD on the computer but when I try to open up the WNA ...
- Feb 14, 2020
Almost certainly too old. This thing dates back to 2013.
There are drivers for Windows 10 and this device.
WNA3100 (N300) Wireless USB Adapter Support | NETGEAR
then here:
WNA3100 Software Version 2.2.0.4 (Supports Win8/8.1) | Answer | NETGEAR Support
rosebud505 wrote:
Because I am off line I'm unable to download any kind of update.
You managed to post this message here.
Try downloading the new drivers and transferring them to a USB drive. Install from that.
Some USB adapters will use the generic drivers that come bundled with Windows.
michaelkenward
Feb 14, 2020Guru - Experienced User
rosebud505 wrote:
That worked.
The download and USB install or the "native" drivers?
I ask for the benefit of anyone with the same issue in future.
rosebud505
The download and USB install.
Not being a techie, that hadn't occurred to me, but it worked easily.
Again, thanks so much!
- michaelkenwardFeb 14, 2020Guru - Experienced User
These days stuff like USB adapters doesn't come with a CD. So you have to get used to downloads.
But that can lands you in chicken-and-egg territory. How can you download the drivers for a wifi connector when you need that connector to get you on to the Internet?
- rosebud505Feb 14, 2020Aspirant
I know!
Thankfully I have a second computer so I could troubleshoot with that, and download the drivers.
Not sure what I would have done otherwise.
There's the challenge.
I was thinking "mobile". The thought of downloading on a limited mobile phone account, or even using wifi, and then getting it on to a USB drive is beyond the skills of many people.
The good news is that the new drivers worked for you.
