Rljohnson247
Feb 20, 2020Aspirant
N300 wireless USB adapter WNA3100
I have installed my N300Wireless USB adapter WNA3100. It says connected but when I try to get the internet is says no connection on the inter
michaelkenward
Feb 22, 2020Guru - Experienced User
Installed on what? A PC? Windows? Version?
What says "no connection on the inter"? Something on the PC? A browser? Something else?
- Rljohnson247Feb 22, 2020Aspirant
The google chrome page when I try to log in.
- michaelkenwardFeb 23, 2020Guru - Experienced User
What does Windows say?
Have you tried running Windows Network Diagnostics?
What about a different browser?
You never did say what version of Windows you have.
These questions are there for a reason. Troubleshooting can be a lot quicker when people answer the questions posed.
It might also help if you said what version of the drivers you are using for this device.
Here's the latest, tweaked for Windows 10.
WNA3100 Software Version 2.2.0.4 (Supports Win8/8.1) | Answer | NETGEAR Support
If you visit the support pages:
Support | NETGEAR
you can feed in the model number and find the documentation, drivers and other stuff for your hardware.
