yackal9's avatar
yackal9
Follower
Aug 08, 2025
Netgear A6100 (AC600) lag spiking every couple of minutes
As mentioned in the title, it was working completely fine 3 months ago but out of the blue it just starts lagging after a certain amount of time.
1 Reply
  • plemans's avatar
    There is a ton of posts on the forums about lag increases on the A6100. I'd do a quick search as there's a bunch of different things that can cause it from windows driver issues, security software issues, to conflicting drivers.
