Kentiiboyy
Apr 10, 2020Aspirant
NETGEAR A6100 Disconnects all the time
I started getting this problem randomly, i dont know why but i hear the windows usb disconnect sound and i loose connection to internet. I have to take the dongle out of the usb and insert it again to fix it and this happens all the time.
You might get better and quicker replies, and find other answers, over in the appropriate section for your device:
WiFi Adapters - NETGEAR Communities
No need to repost there, unless you want to – that will just clutter up the place with duplicated messages – but you might find advice related to your hardware.
I have asked the Netgear moderator to move your message. - malindagraceInitiate
I am having the same problem. The Netgear genie will say I'm connected to my router, but not to the internet. And when it does connect to the internet it's extremely slow. I've been using this thing for two solid weeks with no problem and then today it's shutting off on me constantly.
- KentiiboyyAspirant
I found a video on youtube about the A700 adapter having the same issue and how to fix it, its a problem with a service.
Link to the video here: https://www.youtube.com/watch?v=ELhMSdv3-Xs
I,m thinking there is a service that is running for the A6100 that can be turned of to fix the problem but i have no experience finding stuff like that, so if anyone finds it please tell us :)
It would help to have a simple description rather than having to sit through an inaudible and confusing video. Some of us can read. These things are usually easy to track down, if you know what you are looking for.
