_Line's avatar
_Line
Follower
Apr 03, 2020
Netgear A6100 Genie fail to install
Hi,
Bought a A6100 wifi usb mini adapter yesterday, but when trying to install it, it fails with the message
"Cannot save file: C\\WINDOWS\Downloaded Installations\{73F98748-E365-4BC9-BE2F-C022CCA6100 Genie.msi.
The specified path could not be found. "
Also. sometimes the error code 1628 appears as well.
The messages are the same whether I use the CD installation or the downloaded software version.
When using the downloaded sofware, I just unpack det files to the desktop.
Thank you in regards.
