KoichiroDK
Aug 05, 2019Follower
Netgear A6150/AC1200 drops connection in games
Hi, I recently purchased an A6150/AC1200 for my sons computer. The idea was that he should play Roblox on wifi etc. The installation went fine and I had no problem connecting the USB adapter to ...
Aug 05, 2019Guru - Experienced User
You put running windows latest update. Is it a preview update or which version is it? the preview versions have created issues before.
What driver version are you running for the adapter?
What router are you using? Firmware on it?
It only crashes in games? are you using QoS on your router? Or any other bandwidth controlling services?
What speeds can you get when speedtesting the adapter?
Here's the support page for the A6150
