alleeum
Jul 08, 2024Aspirant
NETGEAR A6210 causing blue screen
Hello, i updated my drivers because of some audio issues, and ever since then i have been having the BSOD every time i try and connect to the internet.
Jul 08, 2024Guru - Experienced User
Updated your wifi driver to fix an audio problem?
And its causing BSOD that you're now linking to the A6210?
not saying the A6210 can't cause BSOD but a better idea of what drivers you were messing with, what you reinstalled, and what makes you think it is the A6210 causing it.
Did you uninstall the A6210 and see if it still happens? or try the standalone drivers for the A6210
alleeum
i just automatically assumed it was the network connector because it’s my wifi that’s the issue. i updated all my drivers through driver easy and didn’t get a good chance to really look through what i was updating. i did a full factory reset on my pc after it initially happened.
- plemansJul 08, 2024Guru - Experienced User
so you used a 3rd party driver installer and are now getting BSOD and think the wifi adapter is causing it?
I'd be thinking its the 3rd party driver installed something wrong, the wrong driver, or some other issue.You can usually roll back updates to an earlier point on windows.
I'd start with that and then just let windows update the drivers.
