Sharak
Jan 20, 2025Aspirant
Netgear A6210 connected to Fujitsu Lifebook USB3.0 port shows Device can perform faster when .....
Hi there, I am seeking advice from knowledgeable persons in the communities to give a solution to my issue: I plug the Netgear A6210 to a USB 3.0 port of my Fujitsu Lifebook. Surprisingly, i...
- Jan 21, 2025
Thanks you guys for contributing to my posts! I have managed to solve Device can perform faster when connected to USB3.0. It is simple: change the A6210 's properties->advanced->USB Max from Auto to 3.0.
Sharak
Jan 21, 2025Guru - Experienced User
What wireless card is in the Fajitsu?
The A6210 is one of the greatest USB devices out there and your internal card might be better (or upgradeable)
michaelkenward
Is?
The A6210 is now a decade old. Several wifi generations behind the times.
Just another user with time on their hands.
- plemansJan 21, 2025Guru - Experienced User
michaelkenward didn't mean to say greatest. Shooties. Typing to fast and distracted with prepping breakfast for turd monkeys.
The A6210 is pretty basic and used kind of a crappy mediatek chipset
