Sharak
Jan 20, 2025Aspirant
Netgear A6210 connected to Fujitsu Lifebook USB3.0 port shows Device can perform faster when .....
Hi there, I am seeking advice from knowledgeable persons in the communities to give a solution to my issue: I plug the Netgear A6210 to a USB 3.0 port of my Fujitsu Lifebook. Surprisingly, i...
- Jan 21, 2025
Thanks you guys for contributing to my posts! I have managed to solve Device can perform faster when connected to USB3.0. It is simple: change the A6210 's properties->advanced->USB Max from Auto to 3.0.
Sharak
michaelkenward
Jan 21, 2025Guru - Experienced User
This smells like a Windows issue to me. Not much that Netgear can do about that.
If you have installed the "Netgear genie" for your adapter you could try removing it.
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
WiFi Adapters - NETGEAR Communities
You might like to search there for messages related to your issue.
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
Check for various troubleshooting tips.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
Just another user with time on their hands.
Sharak
Jan 21, 2025Aspirant
Thanks for your reply to my post. I uninstalled Netgear Genie. But Device can perform faster.... remains.
SharaK
