Mariocaps
Oct 16, 2022Follower
Netgear a6210
Someone know if i can conect netgar a6210 to my xbox one s
Mariocaps wrote:
Someone know if i can conect netgar a6210 to my xbox one sWhat do you want to do with the A6210? Connect how?
It is a USB wifi adapter. It is designed for PCs that run Windows so that they can connect wifi.
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
WiFi Adapters - NETGEAR Communities
You might like to search there for messages related to your problem.
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
Check for various troubleshooting tips.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads. - plemansGuru - Experienced User
You'd be better off checking with microsoft on what adapters are compatible. They'd know which ones work with their devices.
