HeyyDelta
Dec 14, 2024Follower
Netgear A7000 - "Adapter Is Not Found" for driver
Hey team, I have a PC that already has an internal WIFI receiver (Intel (R) Wi-Fi 6 AX200 160MHz). I recently bought a new NetGear A700 WIFI adapter as I use it on a secondary PC that doesn't hav...
Dec 16, 2024Guru - Experienced User
So it works on one PC but not the other PC?
Makes me a bit suspicious of the PC that you're trying to install it on. If you have some security or controls preventing installs.
Is this a home PC? Work PC?
Did you try disabling firewalls/antivirus/or anything else that could be blocking?
