njweb
May 29, 2021Luminary
Netgear A7000 causes Blue Screen of Death on Windows 10. Please help!
I have the Netgear A7000 USB network adapter with the 'latest' drivers (2017 are the latest....) - 'Software Version 1.0.0.15.'
When I use the A7000 on a 16GB 2016/2017 Acer Predator laptop (G5-793-72AU), it works fine.
However, when I use the A7000 on a 16GB 2020 Samsung Galaxy Flex laptop, connected via a USB-C to USB-A adapter (since the laptop has no USB-A ports) and I want to restart the laptop, the laptop hangs on 'restarting' (Windows).
The laptop hangs indefinitely (forever) while restarting; the only thing to get the computer to restart is to unplug the A7000 from the USB port, but then I get a stop code Blue Screen of Death (BSOD) - "Unexpected Kernel Mode Trap".
Can Netgear support please help!
This adapter is still being sold actively and not cheap at $75 retail, so it should be supported by Netgear. The drivers (latest ones are 4 years old) appears to have issues given how many people get BSOD errors with it.
I bought one for each computer, but now one is useless since it does not work... :(
I see numerous people with this issue!
- njwebLuminary
Update:
I tried plugging the Netgear into a USB hub which is then plugged into the USB-A to USB-C adapter which is plugged into my Samsung 2020 Galaxy Book Flex (16GB nVidia MX250 graphics and Intel 'Iris Plus' graphics). Then I could restart Winsows without an issue.
I then plugged the A7000 back into the USB-A to USB-C adapter and this time it allowed me to restart Windows 10 (unlike the issues I mentioned above).
Side note - I also just applied a Windows update - 'Feature update to Windows 10, version 21H1', but doubt that made a difference.
I will keep an eye on how the laptop performs the next few days with the Netgear A7000 plugged in.
- njwebLuminary
The issue is back again. The adapter actually disconnects from the network after a while and cannot be re-enabled without restarting which causes hanging, unless USB plug is removed and then it gives the Blue Screen of Death.
Really frustrating!
- bagg1oGuide
Same here, kernel dump is showing A7000 driver recursion in kernel mode that causes BSOD, as described in other thread.
