njweb
May 30, 2021Luminary
Netgear A7000 causes Blue Screen of Death on Windows 10. Please help!
       I have the Netgear A7000 USB network adapter with the 'latest' drivers (2017 are the latest....) - 'Software Version 1.0.0.15.'     When I use the A7000 on a 16GB 2016/2017 Acer Predator laptop...
bagg1o
May 31, 2021Guide
Same here, kernel dump is showing A7000 driver recursion in kernel mode that causes BSOD, as described in other thread.
njweb
Jun 05, 2021Luminary
Well, as a quick update on the A7000 disconnect, computer hanging on restart with the A7000 plugged in & A7000 BSOD issues on my 2020 16GB i7 Samsung Galaxy Flex laptop (part of which I posted elsewhere):
Attempt 1 / Option 1 - Does not work for all as paulie12 also found:
I tried disabling the RunSwUSB service for the Netgear A7000 adapter, but this resulted in wifi download speeds eventually dropping to USB 2.0 levels (e.g. 200 Mbps to 300 Mbps, with some levels around 168 and some best case scenarios closer to 400 before the drop again).
When I re-enabled the RunSwUSB service, speeds went way up to USB 3.0 levels - 600 - 750 Mbps with the laptop located all the way across the 1st floor from the room where the Orbi RBK853 is (satellites are in basement and top floor).
[Side note - The adapter in the same room as the router gets even more: 858 Mbps on another laptop - a late 2016 Acer Predator G5-793-72AU bought new in early 2017!] The Predator laptop does not have any issues with the A7000 adapater luckily].
Option 1 Outcome Summary - DID NOT WORK FOR MY SITUATION
Disabling RunSwUSB service does not work for everyone, especially for those with internet service above 200 Mbps; I have 1,200 Mbps plan with provisioned speeds up to 1,440 Mbps so i need the fastest USB 3.0 wifi adapter for my laptop (it does not have a mini PCIe port etc.)!
Attempt 2 / Option 2 (for those with a newer computers with only USB-C ports, such as my 2020 16GB i7 Galaxy Book Flex laptop which has issues due to the A7000) - Changing from one brand of USB-C to USB-A adapter to another brand:
This initially seemed to help speeds, but in short it did not help - with the RunSwUSB service enabled, the computer disconnected several times a day at a minimum and required a reboot to reconnect to the network. Unplugging the adapter when the laptop hangs on restart with the A7000 plugged in, resulted in a Blue Screen Of Death (BSOD) crash.
Option 2 Outcome Summary: With this new top-rated (4.8 / 5) name brand USB-C to USB-A adapter, the Netgear A7000 wifi adapter still disconnects multiple times a day, as it did out of the box [with no changes at all to my system], requiring a reboot each time to restore wifi connectivity.
Also, many times the laptop also had a BSOD after I was FORCED to remove the A7000 just to get the laptop to reboot (as soon as the A7000 was removed from the USB port, the latop restarted instantly, per the Restart I performed in Win 10, needed just to restore wifi connectivity with the A7000!!!).
Attempt 3 / Option 3 - Restore 2 'advanced power' options to Win 10 that had been intentionally removed by Samsung for who knows what reason:
Using regedit, I added back the following two important registry keys to give me the MISSING Windows 10 Advanced Power options (those options were not even visible due to a custom implementation - not sure why Samsung decided to remove these options!!!):
i. 'Wireless Adapter Settings' > 'Power Saving Mode' - After adding the key and rebooting, I then set it to 'Maximum Performance' for both 'on battery' and 'plugged in'.
ii. 'USB settings' > 'USB selective suspend' - After adding the key and rebooting, I then set this to 'disabled' for both 'on battery' and 'plugged in'.
I do not know what these settings were set to while they were removed / hidden completely by Samsung; but I think it is safe to assume they were probably set to power saving modes...
Well, this worked the longest, 9 hours of use yesterday, but then today, just when I was about to post that this POTENTIALLY worked with a big caveat, sure enough the A7000 disconnected again ARGH! This was after less than 1 hour of use today. :(
As mentioned, once the A7000 disconnect I have to reboot to restore wifi connectivity. Sure enough I also had to unplug the A7000 in order for the computer Restart process to stop hanging - this resulted in a STOP CODE violation as others here and on Youtube have noted for the A7000.
The only reason I have spent ('wasted' might be a better word given the outcome) several hours a day this past week trying to get the A7000 to work, is that competitors' AC1900 wifi adapters have lower speeds than the A7000 and they are not always consistent in terms of wifi speed... :(
Still amazed this has been on the market since 2017 without a fix from Netgear or whoever is writing the drivers for them for the A7000.
- njwebJun 06, 2021LuminaryQuick update - The powered USB hub solution to the A7000 'disconnecting and needing a forced reboot / crashing' issue seems * to be working! Per Paulie12's 'powered USB hub' solution in another thread, I installed the powered 4 port hub around 8 or 9 PM last night and the Netgear A7000 adapater has not disconnected once all day today, despite using my laptop for the past 4 1/2 hours straight! (Aside from having a hub connected to my laptop being a clunky solution, I am happy that I can get 700 Mbps at a distance from my router without needing to reboot my laptop to 'fix' the A7000 every few hours!). * I'll declare victory if this solution works another 12 to 24 hours or so without a disconnect. Now I just need to find the smallest powered USB hub that I can. The one I bought is top-rated and has individual powered switches for each of the 4 ports and was only $19.99, but it is 'taller' / 'thicker' than I would ideally like). I am not sure there is anything much smaller though... - njwebJun 13, 2021LuminaryNetgear A7000 (latest 1.15 drivers from 2017) on Galaxy Book Flex with USB Type-C ports (so I use a USB-C to USB-A adapter to connect the A7000): DISCONNECTS AND HANGS / BSOD ERROR. Well, the powered USB hub solution only worked with the Netgear A7000 wifi adapter for 24 hours on my 2020 15.6" 16GB Galaxy Book Flex then it disconnected and I had to unplug the A7000 and restart my laptop to reconnect to wifi. Ultra frustrating. The puzzling thing is while many owners havve issues with the A7000 and I am one of them when it comes to the A7000 on my Galaxy Book Flex, the same Netgear A7000 on 2017 Acer Predator works fine, just plugged into a USB 3.0 USB Type-A port - I did NOT disable the RunSwUSB service or perform any other special steps: WORKS FINE, unlike many owners of this adapter. The odd thing is this is the same exact A7000 and it works perfectly for WEEKS on end on my early 2017 Acer Predator laptop which has actual USB-A ports. I have used that laptop to work remotely and the A7000 adapter never disconnects or hangs. I found this post where someone says to use the older driver to prevent issues, but then how come the latest driver works fine on my Predator: Frustrating and puzzling. - bagg1oJun 13, 2021GuideProbably on newer setups something changed in USB controller. Probably not HW itself, but maybe some firmware on motherboard, or controller drivers on host, or whatever that changes quite often. Adapter driver was updated for last time after your Acer was released, so driver probably supported these systems without issues and was tested on them. For newer systems, like mine or your Galaxy Book or whatever that came out year or so ago, kernel driver is outdated and will simply not work, and Netgear doesn't care to even give generic response, so I wouldn't expect them to fix it. I think we can make very safe assumption that only "driver development" Netgear did there, was wrapping generic relatek chipset driver that A7000 is based on with some fancy features, and this work probably was done by employee who not even work there anymore. As Realtek did not update drivers for this chipset for even longer time, I do not think there is anyone competent enough in Netgear to actually fix issues related to original chipset kernel driver. This is why they give no response, they just cannot do anything with that, physically. They could be more transparent, but you know, that would be admitting their support impotence on their own product and no-one high in sales/marketing team would allow that. Sad, but probably true. Cheers.
