greyhorne
Feb 21, 2021Follower
Netgear A7000 driver for manual install
I'm having a problem with the installer not wanting to run. Is there some way I can get the driver for the adapter and manually install it?
1 Reply
What does that mean? What happens when you try?
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
That page will also have any software, firmware and drivers for your device, if they exist.
Did you read this?A7000 Software Version 1.0.0.15 (Windows) | Answer | NETGEAR Support
