Det_onate's avatar
Det_onate
Initiate
Jul 03, 2022
netgear A7000 installation software causing computer to seize
so i reset my computer recently and ive been having trouble reinstalling the drivers for the nighthawk A7000 wifi adapter every time it wraps up from installing i get about 5-10 seconds from it finishing and my computer will seize completely. forcing me to restart which in turn will pretty much void the last actions im running windows 10 pro not sure what to do from here as ethernet is not an option for me.
  • Det_onate's avatar
    Det_onate
    Jul 04, 2022
    michaelkenward sadly there is no native support and my motherboard drivers are up to date that i know of for some reason tho it started working and no longer crashes after i reinstalled my GPU drivers from Nvidia so this problem is resolved for now ty .
  • michaelkenward's avatar
    michaelkenward
    Have you looked to see if Windows 10 has native support for this device? Just plug in the USB adapter without trying to install anything from Netgear and see what happens.
    You could also check that you have the latest drivers for your motherboard. These rarely reach users with all the updates for things like USB and LAN support,
    The people who made the PC may not be the best place to look. These all get motherboards from a third party.
      Det_onate
      Initiate
        michaelkenward
        Det_onate wrote:
        ...for some reason tho it started working and no longer crashes after i reinstalled my GPU drivers from Nvidia so this problem is resolved for now ....
        That's good. Nice bit of research. One to remember for future reference.
        Graphics drivers seem to do more than the name suggests. I guess it is down to the complex relationship between the CPU and GPU.
        Det_onate wrote:
        ...my motherboard drivers are up to date that i know
        Those things can be a beast to track down. It can be a case of drilling down to the chip level. Intel and Realtek, for example, are where Asus gets some chips, for Ethernet and sound. But it rarely updates its support pages to catch new ones. That can be a pain when they adapt to support something like Windows 11.
