Planeto
Jul 14, 2022Aspirant
Netgear A7000 USB WLAN Stick AC1900
Hello Community, why does the Netgaer genie program only show 877Mbit/s when the adapter can receive 1.9GB/s? It jumps back and forth between 977 and 877. I have a 500Mbit's connection. The next ...
Jul 14, 2022Guru - Experienced User
And the update reason? the underlying chip is a realtek chip. If realtek doesn't update it, there isn't anything for netgear to do as they control the basic firmware/driver for the chipset.
- PlanetoJul 18, 2022Aspirant
I thought maybe that would improve the connection, but as long as it works fine like it does now, you don't need an update. Thanks anyway
