felixcasa
May 02, 2023Follower
Netgear a7000 wrong region
Hi! So this problem has been driving me mad! My ISP prevents me from choosing which 5ghz channel to use. Its all automated, the router basically "scans" and picks a channel based on perform...
michaelkenward
May 03, 2023Guru - Experienced User
felixcasa wrote:
The problem is that the netgear a7000 that I purchased (best buy canada) can't see that channel. In the "netgear genie" program, I see the region as EUROPE. From what I can tell, channel 157 is prohibited in europe ? Meaning that I can't even see my wifi network.
If you visit the right section for your USB adapter:
WiFi Adapters - NETGEAR Communities
you will see that you are not alone.
A7000 with the wrong region - NETGEAR Communities
In essence, if you have the same symptoms described there the adapter is not from the "wrong region". You just have a wonky ISP that wants to force the router it provides – nothing to do with the adapter – to use a WiFi channel that isn't actually widely used.
There's a good chance that any other adapter you buy will show the same symptoms.
If you have the same ISP as jfrancoisricard then you should join forces and shout at it loudly to stop messing you around.
Here's something to read all about WiFi channels.
Understand Wi-Fi 4/5/6 (802.11 n/ac/ad/ax)
