semoGPT
May 05, 2024Aspirant
NETGEAR A8000 WIFI 6E - Capped Speeds
Hello Guys,
I'm having trouble using my new WIFI Adapter from NETGEAR.
with this adapter on my computer I'm only getting 200mbps speed download , but if i use the same network with a a built in module wifi6 or the iphone , the same test goes to 1Gbps.
Can someone help me out ?
1 Reply
- Interest121Aspirant
@semoGPT wrote:Hello Guys,
Ensure you have the latest drivers for the adapter by downloading them from the NETGEAR support page. Also, make sure the adapter is connected to a USB 3.0 port for optimal performance, as USB 2.0 can bottleneck speeds. Additionally, disabling power-saving options in the device properties and adjusting wireless modes in the advanced settings might help resolve the issue. If none of these steps work, performing a network reset or rolling back the driver may help restore performance.
