jameskh31's avatar
jameskh31
netgear ac1200 not reaching 1gbps speeds
just as the title says, my netgear ac1200 is will not go over about 330mbps. I have AT&T 1000mbps internet and the wifi modem is 802.11ac capable and runs on 5g. Everything I have looked up says i should get the 1000mbps it is capable of, but i'm not. anyone have an answer??
  • is your device's WiFi card ready to support such speed?
    if router speed is 1000mbps and if your device's wifi card supports only 350mbps you will never reach 1000mbps.
    what's the wi-fi card of your device?
    • jameskh31's avatar
      jameskh31
      Not sure I understand your question. I have the ac1200 wifi adapter, It connects me to the internet, without the adapter I can't access Internet. I have also hit 450mbps once before at a friend's house. My computer has the z390 aorus pro mother board.
      • MAJOR-z-BOMBASU's avatar
        MAJOR-z-BOMBASU
        Guide
        Is this your adapter: https://www.bestusbwifiadapters.com/images/ReviewofNetgearAC1200USBWiFiAdapter.jpg
        questions:
        1. do you connect your adapter to usb 2.0 or to usb 3.0+ port ?
        2. do you run nighthawk in 5GHz mode ? or maybe 5GHz+2.4GHz (so called "dual band" mode) ? you can see it under setup > wifi profiles section on nighthawk's configuration page
        3. if you run it in 5GHz + 2.4GHz, are you 100% sure that your PC is connected via 5GHz connection?
        4. if your PC is connected via 5GHz connection: go to nighthawk's configuration page and check setup > wireless section. Make sure that option "Bandwidth" is set to VHT80 (not HT40)
        5. At the end, please go to nighthawk's configuration page and check dashboard,you can see there indicator of mobile connection quality, do you see there 4G+ ? Screenshot for reference: https://i.imgur.com/6SipzR2.png
