Verodebordeaux
Jul 06, 2023Follower
netgear AC1200
Bonjour
Depuis que j,ai connecté mon repeteur, mon iphone se met en wifi mais je ne peux tout de meme pas aller sur le net. Je me suis connectée sur 2GEXT, 5GEXT mais rien n'y fait
1 Reply
While there are some cunning linguists here, you might do better to seek help in your language community.
For advice in French, try:
Français - NETGEAR Communities
There is no Netgear AC1200 model.
AC1200 is not a reliable guide to model number. Many devices come with an AC tag, but it is essentially a label that Netgear, and other brands, attach to hardware to describe wifi speeds.
Look at the label on the device for the model number. There are several AC1200 USB adaptors, the topic for this section. But these are not repeaters.
