Proteus1
Oct 04, 2023Aspirant
NETGEAR Nighthawk AC1900 WiFi USB Adapter (A7000) Stand damaged
The stand for my WiFi Adapter was damaged, and it's not prudent to place the WiFi adapter into my desktop as the angle introduces stress on the USB connector. Is there somewhere I can get a replaceme...
Oct 05, 2023Guru - Experienced User
or just pickup a cheap usb extension cable and use that. I've done that before when I didn't want a USB driving sticking out of something
- michaelkenwardOct 06, 2023Guru - Experienced User
I was going to make the same suggestion. There is nothing special about Netgear's extension cables.
