Digz
Apr 09, 2020Initiate
Netgear Nighthawk AC1900 WiFi USB Adapter Keeps Disconnecting
I've tried literally everything for this $80 wifi adapter that I bought. It has very fast wifi speed but it just has one problem.. it disconnects every 5 minutes. Perhaps even less than 5 minutes mos...
- Apr 17, 2020
I figured out what the problem was. It's the cord. I just plugged it in directly to my computer and haven't had the problem in almost a week. Thanks for the reply!
michaelkenward
Apr 10, 2020Guru - Experienced User
Any chance that it is a setting somewhere in Windows?
Look at the adapter's properties in Windows and check that it isn't set to allow the computer to turn off this device to save power.
Wifi power saving
