Digz
Apr 09, 2020Initiate
Netgear Nighthawk AC1900 WiFi USB Adapter Keeps Disconnecting
 I've tried literally everything for this $80 wifi adapter that I bought. It has very fast wifi speed but it just has one problem.. it disconnects every 5 minutes. Perhaps even less than 5 minutes mos...
- Apr 17, 2020I figured out what the problem was. It's the cord. I just plugged it in directly to my computer and haven't had the problem in almost a week. Thanks for the reply!
michaelkenward
Apr 17, 2020Guru - Experienced User
That's good.
It is amazing that something as simple as a USB cord can be so picky. I have several that simply don't work as expected. Cheap crap, I suspect.
Ferrit1981
Apr 30, 2020Tutor
Hello there.
Was this problem to do with the orginal cable and dock for the adaptor that came with it?
and did you plug the adaptor straight into your pc or purchase a compatible usb cable?
Its just I have some sort of trouble like this and want to eliminate all areas.
Kind Regards,
Ferrit1981
