Sharak's avatar
Sharak
Netgear USB WiFi adapter A7000 Device can perform faster if connected to USB3.0?
Hi there,  Can anyone who is knowledgeable with the issue help? I have recently bought a "pre-owned" Netgear USB3.0 WiFi adapter A7000 from a seller in www.ebay.com.  After I received it, I install...
  • Sharak's avatar
    Sharak
    Apr 17, 2025
    michaelkenward and whoever happens to read this post,
    I posted my issue: Netgear WiFi Adapter A7000 when plugged into a USB 3.0 port of my laptop shows Device can perform faster if connected to USB 3.0?  Aside from a reply of michaelkenward ( my thanks for it) that the issue might relate to USB Driver of my laptop, no one was interested in helping out.
    The issue as I later found out is the incompatibility of the Netgear USB crade of A6210 that I was using with A7000.  I bought the pre-owned A7000 without the cradle.  I thought that it could be used with the cradle of A6210 that I had owned.  When I plugged A7000 directly with a USB 3.0 port of my laptop or through a USB 3.0 hub, it displays the device is running USB 3.0.
    Sharak_H7
