maisy
May 19, 2019Follower
Netgear wg111t wireless usb adobter doesn't show ssid of dsl modem
hi
i have netgear wg111t usb wireless adapter and installed netgear smart wizard while scanning the network it's not showing the ssid of my dsl modem while it shows the ssid of my other router(aces...
Blanca_O
May 26, 2019NETGEAR Employee Retired
Hi maisy
Welcome to NETGEAR Community!
If the adapter detects other WiFi network then it is working fine. May we please know the operating system of the computer? Please try to add the WiFi network. We also suggest that you change the WiFi channel of your router.
Blanca
Community Team
