somehow
Mar 24, 2019Follower
Netgear wireless adapter AC600
can this wireless ac adapter be used in the dish receiver to get wi-fl for movies
michaelkenward
Mar 25, 2019Guru - Experienced User
The A6100 is a USB device that allows Windows PCs to connect to the wifi.
Check the "System Requirements" in the Data Sheet.
>>>> A6100 | Product | Support <<<<
It will not add wifi capability to anything else.
