Brighty1012
Jan 07, 2020Follower
Netgear Wireless WG111v2
Hi everyone, I can't seem to locate my Network Security Key for my adapter and my product isn't registered as it is relatively old. Any suggestions or support would be appreciated. Thanks
Jan 07, 2020Guru - Experienced User
I'm not sure what you mean by your network security key. Are you talking your wireless password?
the WG111v2 is a usb adapter. the router would have the password.
I'm not sure what you're even using this for. The newest operating system that it supports is windows xp. It was released in 2004.
You can get pretty cheap dual band adapters for $10
