Wifisau
Nov 25, 2023Aspirant
netgear WNA3100M non détecté Windows 11
Bonjour, j'aimerais régler un problème qui m'arrive depuis avant hier et qui me tracasse fortement, je suis passer sous Windows 11 23h2 et j'ai mon petit adaptateur WNA3100M, ainsi que le driver et l...
michaelkenward
Nov 25, 2023Guru - Experienced User
While there are some cunning linguists here, you might do better to seek help in your language community.
Try:
Français - NETGEAR Communities
WNA3100M is too old for Windows 11.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
- WifisauNov 25, 2023AspirantHello, I had previously managed to put NETGEAR on Windows 11, by installing Windows 10 with NETGEAR to install too, then I installed Windows 11 and it worked, except that I can't do it.
If NETGEAR WNA3100M is too old, what should I do?
Sincerely
Leandro- michaelkenwardNov 26, 2023Guru - Experienced User
Sincerely
LeandroTry it with the Windows built-in drivers.
Or buy a USB adapter that wasn't designed for XP.
